Storbe spur gears options?
Patrick
01.02.2008, 08:04 AM
Yeah, I've used that 65t spur as well. It works ok after a few minutes with the dremel.
Because it's so big you might have to drill another hole in the standard motor mount plate or extend the adjustment slot a bit depending on the pinion you use.
Patrick
Find all posts by Patrick
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
