Serum
Serum's Avatar
01.04.2008, 05:36 PM
the novak controllers only work with sensored motors; the newer updated sintered rotors are great, they run stone-cold and are in my eyes considered high-end. Too bad they use a 3.2mm shafts, but novak is about to change that.
the only thing that bothers me is that they use a relative small rotor and a high KV to compensate their lower torque. While their older rotors ran hot, the new rotors work a lot better.
I don't know what application he is using his setup in? (and what setup he has, if he is using the older 4400 without a sintered rotor?) that rotor is a 30 dollar upgrade and well worth the money.
01.04.2008, 09:39 PM
It would be slick if novak would bring out a slightly larger motor with a lower kv. I would buy one just for the low speed smoothness. Just thinking that maybe a hv 6.5 would be a nice setup in a crt.5 or ls10? Run it on 3s or some smaller 4s packs and gear it way down. Still would have plenty of speed and should run very cool with the upgraded rotor.
