ssspconcepts
ssspconcepts's Avatar
01.05.2008, 12:13 PM
I take an electronic laboratories scale (0 to 6kg). I put a stand on the scale, make a Zero, and put my truck on the stand.
Me e-revo, with Panthers Komodo tire weigh 9.4lbs and with Proline badlands tires, it's 10.5lbs.
I wonder if you can get one of those scales at Home Depot or Lowes...I am not at all familiar with the brand or application. I suppose a decent postal scale could be purchased from OfficeMax.
lutach
lutach's Avatar
01.05.2008, 12:22 PM
I used Brian's speed calculator to see how fast your truck is going and it showed speeds of over 66MPH. The MGMs that I have don't cog at all.
othello
HV basher
01.05.2008, 12:47 PM
@ssspconcepts
Truly amazing performing CRT. I like it. If even their (MGM) highest rated 6s ESC is cogging at start up then it's time to reduce pinion size. But it's always good to know the limit of newly aquired components Would be interesting to see your highest Watt/Amp peaks. 2.5-3KW seems realistic with this high gearing and 5s Flightpower lipo.
ssspconcepts
01.05.2008, 12:52 PM
@ssspconcepts
Thanks. I have seen the videos you made...really kick butt! I like how you did the eagletree data insert.
ssspconcepts
01.05.2008, 01:00 PM
Yeah...this is the 2700kv Neu and I was running the only extra mod 1 pinion I had (18T) with a 46T spur...so the cogging didn't surprise me. What did surprise was that it really didn't cog that bad considering the setup. I'll probably order a 12,13, and 14T set and experiment with those. Any takers on what tooth count the cogging will disappear?
I once attempted to run a Neu 1515 2.5D/F with 3S and 12/46 gearing using a MMax and I basically had to push start the darn thing to get it to go! In fact that is the first setup I had in this CRT...I got tired of messing with the MMax/Neu combo and ordered this the 1.5D/F and 22418 from Mike.
lutach
lutach's Avatar
01.05.2008, 01:33 PM
I'll the 14 tooth will eliminate the cogging, but I would like to know your setting on the MGM as well to be completely sure. The Mamba Max has trouble with motor that has a strong magnet connection with the stator. I heard some guys here are having great succes with the Mamba/Neu set up.
othello
HV basher
01.05.2008, 01:49 PM
I would even think that your ESC should handle a 15 or even a 16T pinion depending on grip with this very high revving motor. On 5s your motor could spin well above 50000rpm. The Neu 1512 i use already reaches 40000rpm and is geared 13/52. I thought this is already crazy.
Think about the torque you will have on tip when you gear it down. Your front (and rear) tires will have a hard time to keep up. Spin city ... Prepare to stock up on tires. But it should be fun to drive it this way
lutach
lutach's Avatar
01.05.2008, 01:56 PM
I used 37 volts with my truck and I blew the diffs. Even if you drop to a 14 tooth pinion, you will still go over 55MPH. That is fast and too fast if you plan on racing. You should try a 4S lipo with the 14 tooth and it should put you right at around 40MPH. I love power and speed, but you will have to stock up on parts for sure.
david lamontagn
01.05.2008, 03:24 PM
ssspconcept, did you use the internal controler BEC or you use an external one??
Don't know why, but i don't wnt to take any chance and on my e-revo, i've a MGM 16018 on 4s, and i use an external CCBEC.
ssspconcepts
01.05.2008, 03:49 PM
I am using the internal BEC...
ssspconcepts
01.05.2008, 03:53 PM
I don't race....I live in Western-Freaking-Virginia. When I say "RC car" people go "huh wuts dat?" There are two off-road tracks that are around 60 miles away...but I've never checked them out.
lutach
lutach's Avatar
01.05.2008, 03:57 PM
That's funny. Try and do what David said and you could also use a receiver pack. I had cogging issue with my BKs and when I used a receiver pack with all of them with BEC disabled, they didn't cog anymore.
