DrKnow65
DrKnow65's Avatar
01.05.2008, 09:47 PM
You could do like I did and run an external LVC. I use the Cellshield by dimension engineering. It monitors eacy cell via the balance adapter (any configuration) and has a soft shut off with the option of a temp probe to failsafe to 140* too.
The only issue is that if you run reverse (I don't) it will throw the car into reverse when you get past the "soft" cutoff, as it's designed for airplanes with a zero signal that equates to a cars reverse.
