ICUBoy
01.07.2008, 08:09 PM
lincpimp I like the DIY blacksmithing. It will be interesting to see how it holds up!!
Regards
ICUBoy
01.07.2008, 08:28 PM
GO-RIDE- icarerc.com has plettenbergs, they are in cananada, no us distributors I know of
Linc- ANOTHER sweet ride, are you up to 50 yet?
ilpufxit
ilpufxit's Avatar
??? - 01.07.2008, 08:50 PM
As far as I can see, icarerc.com is a health insurance site. I am looking for help with a busted plettenberg, if there's someone local, I'd really like to know.
01.07.2008, 09:40 PM
its icare-rc.com
GO-RIDE.com
01.07.2008, 09:59 PM
its icare-rc.com
Thanks for the link info. Unfortunately, $250 for a motor is a bit steep for this project.
E-8ight - Tekin RX8 2000kv/4S
01.07.2008, 10:00 PM
agreed.
01.07.2008, 09:19 PM
Originally Posted by cemetery gates View Post
Nice! I had the same idea with the 13t gear from the e-maxx trans. I was able to drill it out, but not tap it. I guess I have to heat it up and let it cool slow, then heat it up and quench it really quick?
Bye
All I did was heat it up to red/orange and let it cool by itself and it drilled and tapped easily. I always chuck my taps in the drill press and use it to keep the tap straight as it threads into the material. To harden the gear, I heated it up till it was orange/red and dropped it into a can full of oil and let it fully cool. I just did the same thing with the 18t gear as well, I will have to try it out in something else.
Regards
ICUBoy
I ran the crt.5 again for another 30min and the gear seems to be holding up fine. Looks like it will last, but I will update after a few more packs.
HAHA, getting there, actually I need to sell off a few as I would like to get a baja ss kit, looks badass!
I also adjusted my MM half way thru the second run. I moved the start power from low to normal. Wow what a difference. The plett starts very smoothly now, almost as good as a sensored motor. I have to hand it to CC and their pc interface, really easy to use and it does make a difference!
