MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.09.2008, 12:56 AM
As far as tough trucks go I think it is down to the LST2 or Savage. I have a Savage and love it. The X design is so much simpler to work on then the older models. I have a friend with an LST/2 and I have to say the savage is the more solid of the 2. The savage has it's weaknesses though. The diffs and dog bones break with lots of power like any truck. The shock shafts can bend. I have never bent a stock shock but I now run the LST2 shocks. Most people who I have seen bend shock shafts are either running 30+ wt oil or have hit something. Other big weakness is the stock tank on the savage. I broke 2 and then did a mid tank conversion which solves the leaning problem some people (including me) have on the stock tank. My mate has broken more tanks on his LST2 though then I have. I have no idea why his tanks break where as with the savage it's fairly obvious.
Edit: Good to hear you are going with the savage. If you break something there are heaps of ways to make it tougher. Just keep the A arms and shock towers plastic and they bounce off just about anything.
ICUBoy
01.09.2008, 01:54 AM
david this is a question I am interested in as well- is ANY savage good to convert or is there a particular one that is tough? Is it true that one should stay away from the E-savage??? I might buy one of the ones with NO engine eg http://www.amainhobbies.com/product_...ducts_id/14436.
It seems odd that e-Savage with batts and charger is only 10 bucks more!!! Is it that much weaker???
david lamontagn
01.09.2008, 02:14 AM
Diffs on the XSS?????????? Everybody tell me that the XSS diffs are bullet proof with the new aluminium cup???
Stay away from the e-savage, it's the same thing that the E-zilla, big SCRAP
01.09.2008, 02:30 AM
big SCRAP
SCRAP? Does that stand for Super CRAP?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.09.2008, 06:55 AM
The 4 bevels in alu cup are pretty indestructible but the ring and pinion can still slip with the flex in the diff casing under extreme load. I'm not saying you will break them straight away they are fairly bullet proof. Just check for slop in the diff and add shims if necessary. Also check the diff bearings as they go eventually and will cause the ring and pinion to die. I had a diff bearing go and the ring and pinion still look perfect even though they would of been slipping like crazy.
If you want to build an electric savage there is a shop called nitronutzz on ebay which chops xss savages. I bought all the stock parts I wanted for under $120 dollars I think. This included tranny, diffs, bulkheads, screws, dog bones, turn buckles and just about everything bar nitro gear, tvp, shocks (i use the LSTs) and radio box. I just need the FLM forward tranny chassis though.
david lamontagn
01.09.2008, 09:06 AM
Which parts i need to fit LST shock on Savage???
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.09.2008, 06:41 PM
This is the kit I use from Innovative-RC but it requires the old style arms. They also have some stand-offs to use the stock arms. FLM also have the parts to do it if you use there alloy towers.
http://www.innovative-rc.com/product...roducts_id=130
david lamontagn
01.09.2008, 06:54 PM
OK thank you, i've take a look at the innovative rc kit, it seam to be very well make.
But why they tell that this kit fit the Savage XSS but with the non-X arm
Which arm do i need to fit with this kit, and do i need front and rear arm?? upper and lower?
And is the non-X arm is as good and solid than the X one??
Thank you!
David
