neweuser
neweuser's Avatar
01.11.2008, 03:51 PM
The plugs are easier IMO. The easiest way is to scrap the inside, put a tad bit of flux in, tin the wire, stick the wire in and use a clamp to hold the wire down and heat the plug up and solder it up....done.
knotted
01.12.2008, 07:48 AM
50 amp rating, what a joke! I use Dean's in my brushless 90 helicopters. They pull over 100 amps continuous for the whole run. No problems at all with the Dean's.
