entjoles
01.12.2008, 09:47 PM
same basic set-up, moved the esc., still need to get a ubec, and i changed to 18 tooth pinion/have not ran it though
also painted a body today , just did a fade job, looks better in the pics then in person, but it will get beat bad come spring
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
01.13.2008, 01:34 AM
nah, that body looks great. good job!
uh-oh - is that a non-hardened steel pinion i see? you might want to try the kyosho plastic spur - that's what i'm going to try once i get my eXT8 back in a week or two. supposedly you just have to drill the holes to 4mm and it'll fit.
nice job!!
Eflite Blade 400 heli on 3s
entjoles
01.13.2008, 02:11 AM
yeah i may try that, i have not run this pinion, i got it with my crt.5 i bought, i will have to get a hardened one then
how can you tell the diff. between the two?
ncalenda
Need for Speed
ncalenda's Avatar
01.13.2008, 01:46 PM
love the paint job, very nice!!!
Do you know how much is weights? Mine is 10lb 5.8 oz with a 5s 6000 in it.
  Send a message via AIM to ncalenda
ClodMaxx
ClodMaxx's Avatar
01.13.2008, 02:22 PM
the last few hardened pinions i bought from RCM have been the near-black color... but maybe the older hardened ones weren't that dark. it was just a guess.
entjoles
01.13.2008, 02:54 PM
thanks, i just should have used more yellow and orange, it got to dark in the back, but it will work
i dont know the weight on it around 10 +
this pinion is a light bronze, so it must not be hardened
what size plastic spurs are available??
44,46,48?
and all i need to do is make the screw holes bigger?
ncalenda
Need for Speed
ncalenda's Avatar
01.13.2008, 08:08 PM
ya, when I talked with Mike last, he said it is only making hardend steel pinion gears now, the steel ones were steel in color, with no bronze.
I ran mine for the first time, wow, this thing is a dream compared to my e-maxx. I can't believe how nice it does on corners.
entjoles
01.13.2008, 08:22 PM
i know, when i drove mine , i got done and 5 min. later i started to take apart my g3r, i knew i would never want to drive it again, and besides i used the electrics out of it
but it is lighter , easy to work on , and handles much better
one large rc is enough
ncalenda
Need for Speed
ncalenda's Avatar
01.14.2008, 01:07 AM
funny, I did the same to my e-maxx!!
entjoles
02.03.2008, 08:38 PM
some new video, very icey snow, no traction
the 2nd one i was jumping the wing breaks off, 25*f temps and xray parts = new parts
entjoles
02.24.2008, 02:01 PM
made a top diff. plate to mount electrics to and will soon be getting a ubec and trimming up the rx wires....
