01.15.2008, 04:23 PM
http://www.pro-lineracing.com/howtot...arison.html#mt
Yes 6.1!
Differential Ratio: 3.3333333333333335
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 16
Total Voltage: 16
Motor KV: 1853
Tire Diameter (inches): 6.1
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0092
Spur/Pinion Ratio: 2.88 : 1
Total Ratio: 9.58333 : 1
Tire Circumference (inches): 19.16 inches (486.76mm)
Total Motor Speed: 29648 RPM
Vehicle Speed: 56.14 MPH (90.18km/h)
Effective Speed Rate: 3.51mph/V (5.64kmh/V)
Effective KV Value: 1853
I think i might need to go down to 10!
Other Ratio: 1
Pinion Tooth Count: 10
Total Voltage: 16
Motor KV: 1853
Spur/Pinion Ratio: 4.6 : 1
Total Ratio: 15.33333 : 1
Vehicle Speed: 35.09 MPH (56.37km/h)
Effective Speed Rate: 2.19mph/V (3.52kmh/V)
