austinmaxx
01.18.2008, 07:22 PM
With the defaut settings on mgm160 controller with neu 1515/1y 4s maxamps lipo in 3905 maxx with 68/20 gearing it didn't impress me, ... it was decent, I want stampede vxl performance in my 3905 if that makes sense...I have not had a chance to run since changing the freewheel setting to "off" and putting the accelerating setting to .013...its raining and 32 degrees today dang it....hope the freewheel setting will help make it seem alot faster...otherwise should I go 5s or 6s on this setup?
Patrick
Patrick's Avatar
01.19.2008, 06:39 AM
68/20 is 17.7:1 final drive ratio, which only geared for low 30's with the 2200kv 1y on 4s. For bashing you can easily go to around 14:1, or even lower for high speed bashing.
I don't know what size spurs you can get for the new e-maxx, but 24 or 25t tooth pinions is what I'd use with the 68t spur for normal driving or racing. After that if your happy with the temps and still want a bit more speed you can still gear up a little bit.
austinmaxx
01.19.2008, 10:45 AM
I have a 58t spur the 24t pinion might reach ..lol ....Its 28 degrees and icy here this morn to I will have to wait for bit......I may go to 5s right now I am using (2) 8000mah 7.4 maxamp lipos in series.....maybe use two 5s 5000 18.5v packs....I already have two 3s 5000 11.1v packs I could run in series...6s too much you think for 1515/1y?
