jdtmaxx
01.19.2008, 11:16 PM
but can i still put the clutch and flywheel from the 2.5 engine to the .28
01.19.2008, 11:24 PM
you can but you have to cut the crankshaft to the same length as the t-maxx and then you are stuck usisng that motor for a t-maxx. I prefer to use any 1/8 scale clutch and flywheel(much stronger) and change out my spur gear to monster gt spur gears, but that only works on black tranny's not the new grey ones, but someone here can tell you how to get mod1(the pitch of 1/8 clutchbells and mgt spurs) on the gray trannys
