Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
MetalMan
MetalMan's Avatar
01.20.2008, 01:16 AM
This is a very intriguing idea... I've already got an old mountain bike with 24" wheels and a rear derailleur and without pedals, an OEM RC Sentilon 12s Lipo 100amp ESC, an Astroflight servo tester, 4 x 12v 7Ah lead acid batteries, and 2 x 5s2p A123 packs + an extra 1s2p. If I could get that gigantic outrunner from United Hobbies that sike linked to, a suitable chain-drive "pinion gear" from http://www.spd-si.com , and mount everything, then I'd have a fully functional electric bike... Now onto Brian's calculator to figure out what size "pinion gear" I would need to achieve 30mph.
EDIT: The motor sike linked to is 180kv. Based on calculating gear ratios, it would require a reduction of 22:1 to run at 30mph tops with 26" tall tires and 48v. I did find that they have a 130 kv version of the same motor:
http://www.unitedhobbies.com/UNITEDH...idProduct=5142
With the same tires it requires only a 16:1 reduction.
