skellyo
skellyo's Avatar
01.21.2008, 03:26 PM
Originally Posted by Sparky View Post
I have reinstalled the old mechanical breaks back on the front. I have test driven it around on the street. It's awesome. The MGM controller is not consistant in braking. That is why I went back to the mechanical breaks on front. It also gives me braking bis. The back is controled from the ESC. I'm also installing a smaller motor Neu 1509/1.5Y. It's too fast @ 22.2 volt. The smaller motor will be lighter and just as fast as this one at 14 volts. I will post a new picture soon. I will let you know how it turns out.
Huh? How do you figure that your motor brakes only control the rear wheels of the vehicle?
Sparky
Sparky's Avatar
01.21.2008, 04:15 PM
Ok, maybe I wasn’t clear. The ESC brakes both front and rear. I set the ESC to light breaking. Then you can put more braking on the front with the servo mechanical brake. That gives you braking bias front vs. back.
skellyo
skellyo's Avatar
01.21.2008, 07:44 PM
Ok, maybe I wasn’t clear. The ESC breaks both front and rear. I set the ESC to light breaking. Then you can put more breaking on the front with the servo mechanical break. That gives you breaking bias front vs. back.
Ah, I understand now.
Sparky
Sparky's Avatar
01.21.2008, 11:50 PM
Here is a photo of the front brakes that I installed.
I used a Futaba S3155 Digital HS Slim Servo.
So far it's working great.You must have brake mixing on your radio.
I would have installed the rear also, but the brake disk and the motor hit each other.
