legobrains
01.22.2008, 05:38 PM
I'm going to take a stab at this, If I'm wrong some one will correct me.
a 2Cell 4000Mah battery will charge in the same time as a 3Cell 4000Mah battery.
If you were to charge those at 1C, then it would be 4Amps. (1C for a 2000Mah would be 2Amps etc, etc...)
So the MAH is how long the power will last in the battery, and that is what you are "charging" back into the pack.
Does that make sense.
