ib4200
nota newb
ib4200's Avatar
01.23.2008, 06:12 PM
you make bigger caps sound like a bad thing...
  Send a message via AIM to ib4200
GriffinRU
01.23.2008, 06:20 PM
They do help battery but not much for ESC...
In MM case above 4S and with higher currents caps start to overheat and once their temp goes up all the good things they used to do for ESC vanishes away. Following with failures first and smoke second...
Also "bigger" caps are not always better then smaller ones, there are specific parameters and placement which makes them good.
