01.25.2008, 11:44 PM
I would say 5s would be better, motor speed is a bit low. However if it is in a buggy it should be ok.
rchippie
rchippie's Avatar
01.26.2008, 07:27 PM
LINC
I understand 5s would be better for the 1950 but im not sure 5s would fit under the body. I would rather have a 1940 but i cant find one i can afford .
Jhautz
The esc is a MM the lipo's are flightpower all of this is in my jammin buggy.
REAL MEN RUN BRUSHLESS
01.26.2008, 07:51 PM
I am sure a 5s 4000 pack (or something like that) would fit, but I do not know your intended setup. If you have the motor, esc, battery, etc go ahead. I am sure that it will be fine, you have good equipment there!
rchippie
rchippie's Avatar
01.26.2008, 08:19 PM
I was only asking about the gear ratio i posted for the 1950 8t hi amp.
jhautz
jhautz's Avatar
01.26.2008, 08:24 PM
Gear ratio looks fine...even a little conservative. You could probably go up a few teeth and still be fine, but that shold be great for a track setup.
to make it...
or break it...
Silent...But Deadly
01.26.2008, 08:33 PM
Ok, your gear ratio is too high for that motor to run most effeciently.
rchippie
rchippie's Avatar
01.26.2008, 10:55 PM
I have a 15t on it know . what would you recomend ?. I got beat by a stinkin 9L last weekend . We used GPS i topped out at 31.7 while skellyo's mbx5 & 9L went 41.3 .
skellyo
skellyo's Avatar
01.26.2008, 10:57 PM
No, no, no...it was 43.4mph
Although, I do believe the MBX5 is going to be torn down here shortly and donate its MM ESC to the CRT.
