jnev
jnev's Avatar
01.26.2008, 08:06 PM
If I understand you correctly, I would think that the banana jacks are for connecting the charger to a power supply. There should also be some kind of harness that goes between the battery and charger like linc said....
rchippie
rchippie's Avatar
01.26.2008, 08:17 PM
There is a cord with 4mm plugs for the power supply out the left side. Then there are 2 banana jacks on top by the jack for the balancing plate.
I just found the online manual for the 610 charger.
http://media.hyperion.hk/dn/eos/EOS0610iNET-MAN-EN.pdf
REAL MEN RUN BRUSHLESS
01.26.2008, 08:50 PM
Those are the otputs for charging a nimh battery, or 1s lipo.
johnrobholmes
johnrobholmes's Avatar
01.26.2008, 08:54 PM
The 4mm banana plugs are for connecting to the battery main power. You have to connect that when you balance as well. You do not have to have the balancing jack plugged in to charge, but you must have the charging jack connected for balancing.
rchippie
rchippie's Avatar
01.26.2008, 09:51 PM
James i found out that plug is the main charge plug & must be used in conjunction with the balance adapter plate for your pack to balance charge.
I thought i heard this charger will let you see the individual cell voltage but i cant find that function.
I found the function i needed. The induvidual voltages are as follows after everything setteled down a few minutes. Is this okay ?.
4.19
4.20
4.20
4.21
