orangecrush
01.27.2008, 11:26 PM
Originally Posted by Just go Play View Post
As far as knowing what mode your in everything will be set to factory defaults as shown in the manual unless you have changed that setting. You do not need to know what any given setting is to make changes.
To program a feature just set to whatever # option you want. If you want the first push once then pull to set. This works no matter what that option may be set to when you start.
Hope that helps.
So I should be able to get into program mode regardless of what settings are already set?
I'd love to but it gives me the rapid beeping after 10secs.
Suggestions?
Mark
PS. My radio is a Spektrum 3.0 and I had it replaced from the factory. Point is, it's BRAND NEW and I haven't changed any settings on it EXCEPT to bind the radio to the receiver.
