BashOn
01.28.2008, 11:41 AM
knotted,
I did some searching on thermal CPU tape. I was going to zip tie my heatsink directly to the mount because I liked the idea of the aluminum acting as a heatsink. Does this thermal CPU tape melt to the ESC? It sounds like a great idea allowing good heat transfer, better mounting and maybe a little cushion.
Please let me know how that works out.
knotted
01.28.2008, 12:18 PM
You probably don't need the tape, but it just bothers me to put the ESC on with no padding. I figured if some padding is used it might as well transfer heat. There is almost no melting of the tape, the MGM never really gets hot enough. The heat sink fins just settle down into the tape a little bit and then stop. This helps keep the ESC in place a bit more securely. I have been using it this way on all my setups for about a year now and it works well.
For the battery stops, I am not sure what to do! Maybe a little foam rubber added to the stops? I hate to think of my $300 batteries buzz sawing into the steel spur!
