Sparky
Sparky's Avatar
01.28.2008, 03:53 PM
Ok, here are my final thoughts after 6 weeks of testing. I probably will not do anymore updates on this thread. I might post a video if I can get it together.
The batteries are the right size and weight for my car “4000mah 6S 22.2 volts”. I had one Maxamps battery fail. It got damaged from not having a full bumper plate on the front side of the battery when a car endos. Make sure you completely support your batteries. Maxamps batteries are not the toughest. I plan on continuing using these batteries. The battery temp was 98F after a 20 to 25 min run
The MGM controller is adequate. It’s not the best performing controller, but right now there is no other that meets the specifications for this application. The breaking and neutral zone are inconsistent and a little hard to control. It is not a professional level controller. It’s a good sportsman class controller. I will be very competitive with it. I’m still looking for a better controlling ESC or a software patch for this one. The ESC temp was 140F after a 20 to 25min run.
The Neu motor is very good. Probably the best part of the conversion. At first I thought it was too fast. It is to fast until you change your throttle EPA “End Point Adjuster” down to around 80%. I would not use a smaller motor because this one heats up after 25min of run time. It’s very fast for a short time and will run at 1.39hp continuous use. If you start running longer the 30min you might run into heating problems with this motor. It’s a great motor and I will continue using this motor. My gearing end up at 15/46. The motor “Neu 1512 2.5df” temp was 165F after 20 to 25min run.
The RC Monster conversion kit was very good. The servo tray took a little grinding to make it fit. You will need a Dremel for this project, especially for making the ESC and brake mounts.
Final word. This type of project is not for the faint of heart. It takes a lot of work.
It just might be easer to run Nitro. In the future there will be more complete kits. This is probably worth waiting for if you are not into doing a big expensive project. Now that it is done, I’m really going to enjoy it. It’s been a fun experience for me and I’m happy with the results.
Ref info
http://2coolfishing.com/ttmbforum/sh...5&goto=newpost
Desmo
01.28.2008, 11:08 PM
Very Nice
Wouldn't the esc and motor run cooler if the motor was at full throttle? So wouldn't a slower motor work better?
