Serum
Serum's Avatar
01.28.2008, 04:20 PM
What room can you get with the 52 spur? (width) 50mm is okay, but might be tight for some packs.
if it's higher, it sits more to the side with the same pinion/spur. perhaps it allows more clearance in the rear for larger motors too. I don't exactly know what to expect, since i am still waiting for mine to arrive.
jhautz
jhautz's Avatar
01.28.2008, 05:25 PM
a 52T spur will push the motor 2.5mm farther over to the side and get you an addional 2.5mm of battery space. Also with the bigger spur you can go another tooth or 2 bigger on the pinion to get the same overall gear ratio (or close to it) getiing another1mm or so in battery space. It might not sound like much, but that extra 3-3.5mm will allow me to fit my TrueRC 8000mah 5s pack right down in there for a nice tight fit. It firs now, but its litterealy touching the side of the motor and I'm afraind the heat from the motor may have an ill effect on the battery if its touching. The 3mm is just a little breathing room for this big lunkewr of a pack. The 5000mah Enerland based packs drop right in and fit like a glove with no worries at all.
to make it...
or break it...
Silent...But Deadly
BashOn
01.28.2008, 05:44 PM
Serum,
I stole the idea for those little legs on the motor mount from knotted, who is doing almost the same build. I just used some Shoe Goo to attach some spacers to the bottom of the motor mount. This raises the 1521 so that it doesn't hit the vertical plate on the motor side. It isn't a problem with a 1515 but the longer can on the 1521 required more clearance.
As far as cost goes for this thing.............................its still adding up.
Just the power system: Battery, ESC and Motor add up to a little more than a grand.
I need my head checked basically..............
I picked up some screws I needed from the hardware store today at lunch, and my balancer for the flightpower came in today so I should be up and running soon. My 5.5 bullet connectors should be in tomorrow or Wednesday. I would have just soldered as someone suggested but I am still finishing painting the body and getting the last bits together.
