rhylsadar
rhylsadar's Avatar
01.29.2008, 06:07 PM
hi
my experience so far from several packs with stock electronics and very moderate bashing. broke the two rear bulks at the screws that hold the shock tower. it seems a very very weak spot due to the screws there. the shock tower is a way to rigid (compared e.g. to savage towers).
one shock bend.
performance with 14 good nimh cells is ok. with 4s trakpower ok (good runtime).
not sure what BL set i am going to put in... if at all. but my plan for now is to go with a moderate powerful set because the truck is quite lightweight.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
Looneybin
03.20.2008, 11:32 PM
i burned both stock motors out the firt run in the mud. no shes sporting a mm/8xl setup with 14cell intelect 4200s. trying mod one pinion and spur gears from hpi
