pipeous
5th Scale Guy
pipeous's Avatar
02.07.2008, 10:24 PM
so you aren't using a pinion then and hooking the motor direct to the shaft?
Pedebeater
Pedebeater's Avatar
02.07.2008, 10:26 PM
Yep, two shafts from the motor directly to the front and rear diffs. Should be sweet.
Faster than a cheetah on cocaine
  Send a message via AIM to Pedebeater
Takedown
WARNING: May become violent.
Takedown's Avatar
02.07.2008, 10:29 PM
Its gonna have absolute raw power.
Pedebeater
Pedebeater's Avatar
02.07.2008, 10:38 PM
Thats what I'm lookin for! lol
Wouldn't be doing this if it wasn't for you Takedown, Thanks.
Takedown
Takedown's Avatar
02.07.2008, 10:53 PM
I try sometimes.
vadda
02.11.2008, 07:05 AM
Hi,
your project is very intresting.
Just i don't understand how you can put diff cups on both side of this motor ?!??!
Output shaft is on one side only.....
Pedebeater
Pedebeater's Avatar
02.11.2008, 05:27 PM
There is a way to get the shaft to come out on both sides. You need to take the motor apart and slide the shaft down, you also need to make a new flatened space on the shaft for the grub screw to grip onto. You can also use a prop adapter, but I will not be doing it that way.
You can ask Takedown for more info on that procedure.
vadda
02.12.2008, 09:32 AM
Thanks,
it's clear.
Pedebeater
Pedebeater's Avatar
02.20.2008, 07:02 PM
I just ordered the motor and a pair of rcm 8mm couplers. I am also still waiting for the custom mount. I might have everything by late next week.
I will be sure to post pics then. Any other comments?
Pedebeater
Pedebeater's Avatar
02.24.2008, 09:22 PM
Now that I did the shaft mod I can mount a coupler on both sides of the motor. Let me know what you think.;)
02.24.2008, 09:49 PM
Looks good, have you fabbed up a motor mount yet?
Pedebeater
Pedebeater's Avatar
02.24.2008, 09:52 PM
I am having a friend machine it out of aluminum. I should have it late this week into next week.
Thank you for the comments
02.24.2008, 09:54 PM
Good to hear, can't wait to see it mounted!
Takedown
Takedown's Avatar
02.24.2008, 10:13 PM
I think you have a good plan. Good luck with the rest of the build!
02.25.2008, 02:46 PM
That motor looks rather neat with the custom yolks- potent...
