02.03.2008, 11:36 AM
Eagle tree data - I think I need to add some puch control... Not liking these voltage dips
Finnster
KillaHurtz
Finnster's Avatar
02.03.2008, 06:45 PM
Does that open for you properly? Its just showing 0 values for everything over 18 min run.... ?????
Anyway, here is mine. I just ran it, and its using way more amps than I thought. I have a couple huge spikes, I'm not sure from what, but generally it easily runs 65-70A. I was thinking it was going to be no more than 50-55A. May need a better/bigger batt. It was quite warm after the 1st run.
Setup is a LMT 1920/10, MM, Align 3S 2100 20C lipo, 14/46 gears and 1:10 scale road rages. 2020g with the heavier 1/10 tires. Was doing about 42mph+ on radar, but was hard to get a good # as I was alone and LVC was kicking in on top end I think (no wonder w/ amp load.)
I hear you on the RCM bash btw. I'll get back to you about that.
