DUde, ur going about this the wrong way, you need different motors. COnsider what coolhand said. ITs like runing a 9l on a 7lb truck. WOuld u REALISTLICALLY run a 9l on a 7lb truck? No! u go for motors that use less batteries, and have higher rpm? The only reason motors like the 9l are use is for the torque. But since the wieht is cut in 1/2, you dont need that much torque.
