02.04.2008, 10:01 PM
Well, to cure "too much current through receiver" issue all you would need to do is simply wire up the positives and negatives of the servo's to the UBEC outside the receiver (basically, bypass it). This way, the current just goes straight through the wires.
However, you would obviously still need to power the Receiver, and the signal wires would need to reach the receiver as well...
