02.05.2008, 03:50 PM
Also may be hard to control the equivalent of the "diffing-out" action if the front lifts. I'm sure you know what running an unloaded motor does...
Maciolus
02.05.2008, 04:25 PM
You should also consider differenciating drag brake setting between front and rear motor.
Great project. Lot of work and setting. I keep my fingers crossed!
MetalMan
MetalMan's Avatar
02.05.2008, 05:42 PM
Good point. If only CC had an RPM limiter built into their software... Hopefully with the rear having more punch control, wheelies won't be an issue. Although a torque limiting setting would be ideal since punch control will limit mid-air control.
It will be a lot of work to get it set up properly, so I too am hoping it will work well! (otherwise it'd be somewhat of a waste of time/money).
One current concern of mine is the strength of the stock diffs. Sike has been having issues even with the Hot Bodies 10/43 diffs (or at least the bearings). I might have to try out the buggy diff conversion, which could actually help because then I could use a smaller motor with a higher kv (it's been difficult finding a motor with ~500 kv, that's not too big).
For the stock Revo diffs, here's what I'm looking at for two motors:
http://www.hobbypeople.net/gallery/108522.asp kv of 480
I work there, so I should be able to get both motors for ~$100. On 5s A123 and the stock diff ratio (37/13), it should reach ~45mph, which is perfect for beating the nitros.
If I were to switch to buggy diffs (43/13), a motor of ~540 kv would be suitable, as would a motor of ~610kv for the truggy diffs (43/10)
jhautz
jhautz's Avatar
02.05.2008, 09:40 PM
Possibly the R1Pro speed control would be usefull. I understand that it has a current limiter built into it rather than just a spool up timer like the CC controlers. A current limiter would act very similar to a torque control limiter.
Actually the current limiter is the reason I really want to try the R1Pro in one of my buggies. I think it could be much more effective at dialing in the power for optimum traction.
to make it...
or break it...
Silent...But Deadly
E-Traxxer
02.06.2008, 01:08 AM
Sounds interesting to say the least!
I've always pondered using a motor per wheel with a slipper on each motor as a sort of "slip diff", but this idea sounds much more involved. Can't wait to see it how it'd function.
MetalMan
MetalMan's Avatar
02.06.2008, 01:57 AM
I'm familiar with that feature of the R1 Pro. Unfortunately, it is much too expensive, especially for me to use two of them.
Only potential problem I see with the "slip diff" is it not being able to handle enough torque. But if that could be worked around, then it should work great.
