Go Back   RC-Monster Forums > Support Forums > Team Tekin
teknorc
02.06.2008, 03:24 AM
Same here. I'm running one on 4s without a proper LVC. I'm just testing things, but hope the Hotwire interface is out soon so I can run a full pack without worry. So far though, I really like this controller. Small and compact. It was a little more work to wire up since you have to solder everything up. The RX8 should hopefully be out in a couple/few months, so the days of running an under-spec'd ESC with an external BEC are almost over :)
Tekno RC - Performance Parts
jhautz
jhautz's Avatar
02.06.2008, 03:45 AM
How has it been doing heat wise for you. Any thermal issues in a 1/8 yet?
to make it...
or break it...
Silent...But Deadly
teknorc
02.06.2008, 12:48 PM
Before pulling it off the track (so I wouldn't damage my batteries due to no LVC), I ran for over 10 minutes in a Losi 8B/4s/Feigao 11L. No issues whatsoever. The ESC temp'd at 120-130 (no fan or heatsink). Very smooth controller.
jhautz
jhautz's Avatar
02.06.2008, 12:58 PM
Nice! Is that buggy set up with your clutch system?
to make it...
or break it...
Silent...But Deadly
teknorc
02.06.2008, 01:21 PM
Of course
I have it set up identically to how the eRevo clutch is set up. I'm using Racer's Edge Revo/Maxx clutch bells. They are hardened (I verified with the manufacturer) and use 5 x 10mm bearings so there is extra material around the bearings. The Traxxas clutch bells use 5 x 11mm bearings so there is very little material/strength around the bearing and they are not hardened. They can break which is why Robinson insists you use their clutch bells with their spur gears.
With the compact flywheel, the setup can be put in many places. The Revo clutch bells are also a couple mm less in diameter than a 1/8 clutch bell.
0 issues with the clutch setup in my buggies and truggies so far aside from the e-clip popping off once. Been using a screw with thread locker and some shims to secure the clutch bell since (like normal people do :) and problem solved. Plenty of power and plenty of run time. I didn't feel the vehicles slowing during a 15 minute main. I was able to clear all jumps at the end of the race just like at the beginning. Using 4s/6000 in the buggies, 4s/8000 in the truggies.
02.06.2008, 02:35 PM
Sounds like some good info there.
I have modded a 4tec clutch bell and will run it with a your clutch adapter in my 2 speed yusa rally (like an inferno gt). It is 1/8 scale and geared pretty high so wee will see how it runs. I am using an integy 3 shoe al clutch and we will see how it does. I had to turn the flywheel down to fit, but the integy flywheel is larger than a stock or lightweight traxxas. Motor is a 2600kv aveox and I am using a quark 125 airmaster esc. 4s lipo to start and I may step up to 5s for speed runs. 4s should do 70mph in second, so I may not bother with 5s!
jhautz
jhautz's Avatar
02.06.2008, 04:41 PM
Originally Posted by teknorc View Post
Of course
I have 2 XB8s set up right now. One with the clutch and one with a conventional direct drive. They are both running identicle setups... Same ESC, same motor (Neu 1512/2.5D) same lipo, same gearing, tires, shock setup, everything. I did it so I could compare the performance with and without the clutch.
So far I like the clutch setup, but can I ask what shoes you are using? I am using the M2C 3 shoe aluminum shoes with the Racers Edge c-bell. The lightest springs they make for that clutch are .9 and I still wish it would grab a little sooner. The M2C clutch can't be setup with the shoes reversed. Any recomendations for a good clutch setup? I was thinking about leaving 1 or 2 springs out completely or possibly going to the stock revo shoes in a reverse(leading) setup.
EDIT: just a note. The one with the clutch runs cooler temps on the esc but higher temps on the motor.Temps are not bad on either one but its a detectable differance. Run time on them is most identical. I can get around 17-18 minutes of race condition running on either setup with a 5000mah 4s pack.
O yea... And I need to decide which of these XB8s to test the R1Pro in. I'm thinking the conventional one cuz it runs higher esc temps so I'll get a better idea of what the R1 is capable of.
to make it...
or break it...
Silent...But Deadly
Matthew_Armeni
Matthew_Armeni's Avatar
02.06.2008, 11:43 PM
He's running stock Revo shoes in the leading position with a spring I'm pretty sure. The M2C's can't be run backwards? Weird. What if you remove the springs, can they be put on backwards then? What ESC you are running? I wanted my clutch to engage a little earlier as well but didn't like how it felt without the spring so I altered the throttle curve on my MM. Instead of a straight diagonel line from 0-100 I raised the start point to about 15. I drew a picture to make it easier to explain, the one on the top is normal, the bottom is mine. Gave it more snap but still good controlable clutch feel.
  Send a message via AIM to Matthew_Armeni
