jhautz
jhautz's Avatar
02.07.2008, 01:07 PM
I have one older MM that is slightly sensitive on the overvolt on 5s. It works perfectly if I change my charger setting to charge to 4.15v per cell (20.75v for the pack) rather than 4.2v per cell. If I charge the pack all the way to 21V it doesnt want to start. I need to drain 100mah off the top of the pack and then it works perfectly. The other MMs I have arent bothered by 5s and work perfectly. These are all the older style though.
Try seeing if a not quite completely peaked 5s pack will let tthe MM start up.
Originally Posted by Finnster View Post
Uh-oh, did this get changed in the new firmware? I have an older MM that runs 5S well. I gen don't use it for that, but its nice to have. I updated the firmware, so I wonder what it will do now...
I've had no issues on mine after the upgrade. At least no issues that werent there before the upgrade.
to make it...
or break it...
Silent...But Deadly
I will check again MM...
GriffinRU
I will check again MM... - 02.08.2008, 12:00 PM
But I have a solution which will solve all problems including LiPo support (cutoff) for 5S and 6S.
I won't recomend running above 6S or 26V.
Picture located here.
dadnjesse
02.08.2008, 12:22 PM
Do you have the specs on that cap that you soldered on!
GriffinRU
02.08.2008, 12:33 PM
1800uF 35V
16x25mm
3820mA/0.014Ohms at 105C 100kHz
DON't TRY this setup!!!
GriffinRU
DON't TRY this setup!!! - 02.08.2008, 01:24 PM
I encounted serious problems with this setup, not quite sure why. But I do need to investigate, it cogs like crazy at mid to high RPM...
Sorry, update will follow.
dadnjesse
02.08.2008, 02:40 PM
Thanks keep us informed
