MambaMaxx Old Edition on a Zippy 5s
Looneybin
MambaMaxx Old Edition on a Zippy 5s - 02.08.2008, 12:45 AM
alright so i have to get this straight. i have read all the threads and i still need a little advice. i have a MM with the older style FETs. anyone think a 5000mah 5s1p zippy would be a bad idea. its for a 1/8 buggy with a 8xl. i am a basher so im just looking for it to be all around fun not neccessarily insane. i just want to order the pack already. i would get a 4s but they are out, plus i have heard a lot of great things performance wise about 5s. yey or ney. thanks
jhautz
jhautz's Avatar
02.08.2008, 12:54 AM
Running the MM on 5s requires more care than running it on 4s. Improper gearing can eaily overload it on 5s. But other than that I dont see any reason why not. I run my buggy with a MM on 5s all the time when not on the track.
Just watch your ESC heats carfully untill you are comfotable that you have it geared correctly and you arent overloading the esc.
The 8xl might be a little bit hot of a motor to run on 5s consistanly on the MM. IMO you would would probably have more sucess with a 9xl or even a 10xl on 5s. It would keep the heat down on both the motor and the MM and still have plenty of power. I ran my cen buggy on 5s and a 10xl and was able to walk on the local nitro bashers with modified Novarossi 28s in their buggies, so there will be plenty of speed and power.
to make it...
or break it...
Silent...But Deadly
Looneybin
02.08.2008, 12:57 AM
oh and i am adding a extra novak large cap like many others. i may also add larger caps then what it comes with if i can find and order the correct ones.
Looneybin
02.08.2008, 01:03 AM
thanks. um i also will be running a fan, on it and all. i kinda already ordered the 8xl since i expected to run 4s. i'll have to see if the 4s becomes availible in the next week or so and if not i may contact mike about swaping out the motors. also i ordered the 18 tooth pinion cause that was just copying a similar project. oh and its also a ofna lxone. thanks again
crazyjr
crazyjr's Avatar
02.08.2008, 02:08 AM
I got away with a 7xl on 5s, but that was in february and temps were in the 50's. when it warmed up it did get quite hot
