capitol
02.09.2008, 10:50 PM
Ok, this is what I'm reading and understanding.
First, which LVC should I get with my setup?
About the chargers. I thought i read awhile back the Brain 977 had problems with false peaking etc. True ?? Should I just get the newer brain or is there a better Lipo charger available like th Hyperion. I like the built in balancer idea.
Next, the 5S lipos sound good. The 6S lipos sound even better, but I don't want to push it.
I read get good brand Lipos. The two brands mentioned are TrueRc and Enerland. Is one better then the other or is it all opinion? If I spending the money I would like to get a top end brand. The money really isn't an issue.
I have two more short questions. Can you guys guess an approximate run time with 5S 8000mah batteries. I know it depends how I drive the truck, but just a guess would be cool.
And finally... will this new set up smoke on of those new 16.8 volt e-maxx. I kinda think (would hope) my current set up will, but I wanna make sure
jhautz
jhautz's Avatar
02.09.2008, 11:01 PM
Yes. It will SMOKE the new stock emaxx.
As far as lipos go. You can go with higher quality packs (enerland) and then you can run smaller capacities cuz they will be capable of putting out the amps that your system will draw. But, the smaller packs will provide shorter run times.
The lower capability packs (TrueRC) require them to be a higher capacity to make them capable of delivering the amp output you want. This will deliver the longer run time and be capable of delivering the current you need. But, the bigger packs weigh more. More weight can cause more strain on the drive train and such.
to make it...
or break it...
Silent...But Deadly
