sikeston34m
sikeston34m's Avatar
02.11.2008, 07:59 PM
The 1200kv motor is an 8 pole to, so the lower rpm and lower pole count would be easier on the esc. Do you think this size motor would be powerful enough to move the revo around? I know that the 10 pole would have more torque than the 8 pole motor, but is it a big difference?
IMO, the 3026 1400kv has advantages over the other ones.
Higher kv, more gearing options that are readily available for inrunner use.
The built in cooling fan. This isn't an option with alot of outrunners.
25mm motor mount spacing - it's compatible with most mounts.
It has the highest continous amp rating. It's tough.
Center diff
ilpufxit
ilpufxit's Avatar
Center diff - 02.11.2008, 08:30 PM
You'll never look back from that center diff. Handling and control are way better than a locked center can deliver. Once you get tired of burning wheelies that is.
02.11.2008, 08:42 PM
Just saw the other thread with Mike's custom center diff that has the slipper built in. That looks perfect for this conversion. I will wait and see what size spur it has and then buy the motor. I think that the 1400kv motor will be fine with the quark esc, even with the high pole count and motor rpm. Does quark spec max rpm with various pole motors? I do not remember seeing that info, but have never specifically looked for it.
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
02.12.2008, 03:11 AM
I was wondering about that, I never did see the slipperrential for sale?
rccna.com
sikeston34m
02.12.2008, 04:59 AM
There are much cheaper ESC's that boast such max rpm figures as 210000rpm (2 poles), 70,000rpm (6poles), 35,000rpm (12 poles).
I really don't see the Quark's switching ability has being a problem.
The max. rpm of 25,000 on 5S is also being figured unloaded isn't it? I doubt the motor will ever hit that unless you're jumping at WOT.
02.12.2008, 11:15 AM
I did not think it would have issues either. WOT jumping, that sounds like fun, and flipping and tumbling. And most likely some broken parts! HAHA
