02.12.2008, 06:58 PM
The lack of gearing is a good point. I will use an outrunner so I will have a slower turning, higher torque motor. The lack of gearing will not cause me too much of an issue due to that motor choice. The std slipperential with the added gear reduction works well. If I made one for myself, I would use a 46t diff gear, as it would affort more space for a similar sized spur gear, that would not contact the diff output on the slipper side of the assembly. I usually run 46t spurs (modified mgt spurs to fit the revo slipper).
E-Traxxer
02.12.2008, 07:07 PM
I think I'm going to first go with a standard slipperential with a revo slipper, this will allow me to put the motor in a good distance above the driveline. It will also allow me to use a somewhat crazy idea to adjust the gear mesh (not having to move the motor to adjust it). I wish I could explain it with words, but I'll have to draw it to explain. On to Solidworks tutorials!
E-Traxxer
02.12.2008, 09:46 PM
Just doing some gearing calculations, and I was wondering what I should aim for to be the final reduction ratio with my setup?
02.12.2008, 10:11 PM
Not sure, what motor, batterys, etc are you planning on using. I usually aim for around 35k rpm motor speed, and 40mph vehicle speed. You are going to use the revo spur gears, correct? So you have 36, 38, 40t spurs and pinions from 25t down to whatever will fit without having part of the gear reduction assembly contacting with the motor.
E-Traxxer
02.12.2008, 10:25 PM
I'm using an LMT 2240 14t (1057 KV) on either 8s or 10s lipo, 40 series Moabs. Using BrianG's calc I can get anywhere from 10:1 to 20:1 fairly easily, but is there a way to calculate the optimum ratio for my truck?
Last edited by E-Traxxer; 02.12.2008 at 10:30 PM. Reason: had 24t posted instead of 14t, quite a difference!
02.12.2008, 11:08 PM
Somewhere between 15:1 and 17:1 looks good. That would be pinion/spur of 18/40 (primary) and secondary of 20/46 for 10s lipo. For 8s lipo you could do 20/40 primary ratio
E-Traxxer
02.12.2008, 11:45 PM
Alright thanks! I think I have a good pinion selection for the 14:1-17:1 range if I go with a Revo-style slipperential, which is probably going to be my route.
I now have another question (which is somewhat unrelated), but does anyone know if Brushless setups have regenerative braking like Hybrid cars do? Reason I'm wondering is because I'm thinking of using mechanical brakes for the bias (and to have less strain on the motor/esc), but if there would be a noticable decrease in runtime, I'd veto it. I'm assuming that regenerative braking hs something to do with mechnical brkes on a hybrid car, and wouldn't be applied to this scale of a system, but just wondering.
Also, how many amps does a normal radio setup pull? By "normal" I mean dual steering servos and a reciever. And if I use an external BEC, wouldn't it put a bit more strain on the batteries than if I used a seperate reciever pack? (might seem random, I know, but I just want to know if I should get an external BEC or not, rather use a reciever pack if there is a difference).
