Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
sikeston34m
sikeston34m's Avatar
02.13.2008, 10:04 PM
Originally Posted by MetalMan View Post
The 26650 cell size is a standard size, which is why many cells conform to it.
Regarding the lower voltage of A123 vs these Sony cells, these Sony cells also weigh about 20grams more each. 5s2p A123 (16.5v nominal) weighs 700grams without wire, and 8s2p Sony (14.8v nominal, I'm assuming) weighs 720g without wire. So the A123 will take up more space, and have slightly lower capacity, but weighs less and will be able to charge faster.
Yes those are some good quick figures you did there Metalman. Can't argue with that.
I'm not sure how readily available these are. I know they are made in Japan. I got a box of 25 cells cheap! Quite a bit cheaper than the A123 cells. So there's a plus right there.
Being able to fit these easier is a plus also. It's something new to me, so I'm gonna give it a shot and see how it works out.
Also, the advertised cycle life at 10 amps is 1000 cycles. They should live a pretty good while.
I'm building packs tonight. I got my first one done. I need to order me some 4S balancing leads. I'll go with two 2500mah 4S packs for the E maxx.
02.13.2008, 10:50 PM
Looks interesting, How are you attaching the cells end to end?
You do need to test these, if they are ghood for 15-20c discharge rates, they would be a good solution. Are they available online for sale?
sikeston34m
02.13.2008, 11:00 PM
I don't like the idea of straight soldering cell to cell. There's ALOT of heat involved with doing that. It might be ok for Nimh or even A123, but I don't feel like it's a good idea with Lithium Ion.
You can solder to them, but you gotta get in and get out quickly. Afterwards, I like to quickly cool the solder with a wet cold cloth. It sucks the heat right outta there.
On the 18650 and smaller cells, there is a neoprene gasket under the positive end. If too much heat is applied, this will melt and then leak electrolyte. Not good. So much care needs to be taken. I'm not sure if the 26650 cells have this same gasket, but I'm not taking any chances on that.
First I scuff the ends lightly with a Dremel tool.
See the copper jumper bars? I solder each end of a jumper to a cell. Then I carefully fold it over until the cells are end to end, taking care to make sure they are square. This also provides a nice convenient solder spot to attach balance leads.
I then apply 1 layer of heat shrink, attach the power lead, then go back and put one more layer of heat shrink on. Double heat shrunk for toughness.
I'm hoping these will make for some good bashing packs. They not be the best for all out racing, but I think they "might" do.
I do know where a few are. PM if you want more info Linc.
sikeston34m
02.14.2008, 12:20 AM
Captain! We're ready to give her all she's got!
Now if this nasty weather would just clear up.
02.14.2008, 01:13 AM
Well that is certainly the quick and dirty way to get them to fit! Good thing those cells have metal cases!
Time for some good testing. Do I need to send you a hacker c50l of the apropriate kv so that you can load them heavily? Seems like the inrunner motors can produce higher amp spikes than the outrunners, bad for running but good for testing.
othello
HV basher
02.14.2008, 10:06 AM
I don't use the Sony 26650VT but the smaller 18650vt (1100mAh -> 9s2p in my truggy). Those have the same characteristics but feature a lower Amp rate due to their smaller size. First off you won't need any balancing cable. This cells do remain perfectly in balance. Charge them up to 4.1 or 4.2V per cell and you are good to go. I don't use an LVC since summer 2007. Capacity hasn't changed noticeably still 2200mAh can be charged back.
Their weakest point is a constant drop in voltage during discharging (your car gets slower and slower) and when it comes to power density A123 cells are superior, as they can deliver up to 100A per cell in a 1p config (1 A123 cell delivers up to 220W burst but may drop voltage down to 2V). At 50A the sony 26650 will drop below 3V per cell and at the end of discharge even lower so you might get up to 130-150 Watt per cell. If you don't expect lipo or A123 performance than you won't be dissapointed as those cells are very reliable and uncomplicated when it comes to handling: good bashing cell for a milder setup.
sikeston34m
02.14.2008, 07:52 PM
Thanks for the input Othello. I was hoping you would join in here.
I just finished with the 1st test run. It is true that the voltage drop curve is different. I noticed that.
1st part of the run was awesome. It would jump out the hole like gangbusters. I had to watch that itchy trigger finger or it would land on it's lid from a backflip. These cells do deliver good amperage. They didn't even get warm with this setup. As the run progressed, the urge to flip or do wheelies slowly "went away".
I had my LVC set at 3.0 volts per cell. Should I lower that some? Sony says these can be discharged to 2.5 volts per cell. What got me was, these packs didn't just dump like lipo's at the end of the run. It would still go, but I could tell it was definately on the LVC, so I just stopped. I ran it hard and the run lasted 25 minutes. I'm charging them back up now, so I'll see how many mah my superbrain puts back in them. I don't feel as if 5000mah was discharged this round.
From the looks of things, these make GREAT bashing packs. They are tough. They are somewhat heavier than Lipo, but they do deliver.
