How much charge is too much?
orangecrush
How much charge is too much? - 02.15.2008, 12:27 AM
I know when you charge a lipo, by the time it's done, it's usually a volt or so higher than it's listed voltage.
I'm curious because I'm charging a 6000mah 5S battery (18.5) and it's at 20.104 volts and is still charging.
It's on a 606i charger with balancer and in a lipo sack so I'm gonna let it keep going. Perhaps it will shut down shortly.
Was just curious how much "overage" is allowed in general without causing problems. Surely it must be okay, I'm assuming if everything is in working order, it should shut itself off.
Thanks,
Mark
