jordan...
one.five.two.seven
02.16.2008, 08:11 PM
sorry, i never mentioned i will be running it in my UE-Gmaxx (build thread in the Gmaxx section). I'm not going to be racing it, so i'm definately wanting it to be a bit overpowered
Looks like the 1950/7 is the go as my truck is full Alu/Carbon. So, am i right in saying that in a larger vehicle, the 1950 will run cooler and not be pushed to the limit, but be a tiny bit slower than the 1940 would be on 6s?
i really appreciate all the help, thanks guys
jordan
jhautz
jhautz's Avatar
02.16.2008, 08:31 PM
Yes it should run cooler than the 1940. No it shouldnt be slower. With the bigger motor you can pull taller gearing to make up for the lower RPM.
to make it...
or break it...
Silent...But Deadly
jordan...
one.five.two.seven
02.17.2008, 05:19 AM
ok, so i've been crunching numbers in the calculator. I've been using 51/20 as a benchmark gearing (have no idea what pinions to consider with this one):
Enter Front/Rear Differential Gear Ratio (?): UE 1/8 scale
Enter Transmission Gear Ratio: E-maxx 2nd gear
Enter Spur Gear tooth count (?): 51
Enter Pinion Gear tooth count: 20
Enter total battery voltage: 22.2v
Enter kv rating of brushless motor 1867 (Lehner 1950/7)
Enter tire diameter in inches: 5.8
Total Motor Speed (?):41447.4 RPM
Theoretical Vehicle Speed (?): 49.23 mph (79.09 km/h)
not too shabby!! but then i tried with 51/25 gearing:
Enter Pinion Gear tooth count: 25
Theoretical Vehicle Speed (?): 61.54 mph (98.86 km/h)
thats more like it with tyre ballooning it pushes the 'theoretical' speed way over 60
Is it weird that the motor rpm did not change with the change of the gearing? Would it be alright to run that gearing, no warnings came up on the calculator, but would it be harmful to the motor or ESC? (probably going to run a MMM). I'm guessing some cooling issues might be experienced, and maybe a total lack of bottom end
thanks alot
jordan
