Matthew_Armeni
Matthew_Armeni's Avatar
02.18.2008, 07:24 PM
Originally Posted by Gee View Post
Like what makes the BEC different from a receiver pack? With a BEC you need to remove the red wire but a receiver pack you don't?
With an external BEC and Novak's ESC you probably do not have to remove the red wire as long as you keep the ESC switch off like the directions state. The BEC and rx pack basically the same as far as the rx and esc are concerned, so Novaks wiring must be different somehow with respect to turning it on and off.
  Send a message via AIM to Matthew_Armeni
VWT4
02.19.2008, 11:22 AM
I thing the issue is that the Novak HV gets the current for the BEC from ONLY one of the connectors (I think is the right one).
If you use 6 or 7 NiMH cells packs the BEC works reducing 7,2 or 8,4V to 6V for the receiver and servos.
Using a 12V lead battery or 4S lipos in this connector will overload the BEC and can burn it.
