glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.24.2008, 01:40 AM
I really don't want to talk motor theory, but keep this in mind when studying motor specs... on the Neu site I think the amp draw specs are max amps at the max rated voltage. The watts should be basicly equal on all winds. Lower kv motors will naturally have an efficiency advantage due to the lower currents they use to make the same horsepower.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
