02.24.2008, 02:12 PM
any motor suggestions? i will probably use the mega bur i want to know is theres anything else out there that will work without breakin the pig!
jhautz
jhautz's Avatar
02.24.2008, 02:21 PM
I will caution not going with any wider (diameter) of a motor than you need to. The motor diameter plays into how big of a battery you can fit. The 36mm can motors give you the most room. The neus and neus with fins give you less room.
to make it...
or break it...
Silent...But Deadly
