Revracer
Revracer's Avatar
02.24.2008, 06:18 PM
all you have to do is take the electri clutch off and put on a pinion gear from mike. thats it. and most people setup the clutch loose so it almost instantly grabs considering that brushless makes instant torque... it still will perform well. might make it do wheelies a little easier if you make it grab hard at slightly higher rpms but im not sure.
