he complained about identifying ring gears earlier in the thread, it really was relative information, but thanks for the sarcasm suicideneil, i would have done the same
all stock traxxas ring gears are 2mm, maximizer made both a traxxas and robinson 3mm ring, "stock" robinson's are 2mm, the 3mm are for use with aluminum cups, like i said, robinsons are smooth on the back, easy to tell, and yes, only robinson ring gears need a different pinion, the teeth look sharper on a RR pinion and they are usually lighter in color, anything i didn't answer?
