What to do with an old Hacker Master 70-3P Opto!!! -
02.05.2008, 03:37 PM
This is what I plan to do with it. I finally found it and looked at the MCU and it is a ATMEGA8-16AI and it just happened to be the same as the one found in a little 1/18 scale controller that uses the updated ATMEGA8-16AU. I will take pictures later today. Artur are you able to switch the MCUs to see if we can create a Hacker Frank"BL"enstein?
