Cain
02.28.2008, 10:30 AM
Thanks for the info on the tray. Makes sense then on the screws. If you take the tray off at all, I would like to see how it bolts together with the plastic bottom and all.
As for when the MBX5 ultimate tray will be ready, If Dan can make mid march that would be awesome, however, based on what is on his plate and his statements, I am thinking probably end of March at the earliest, maybe Early April.
When do you think you will get a chance to run your buggy at all?
macr0w
macr0w's Avatar
02.28.2008, 11:27 AM
You have to be careful I guess when mounting the tray. What I did was to use the existing motor mount holes in the chassis. I cut the spacer to fit where I wanted it. Then used some short bolts and nuts with lock washers on the 2 holes that were not under the tray itself. And I used short (1/2 inch) coarse thread wood screws for the 2 holes that were under the tray as to not go all the way through the spacer into the tray. Then I used the same short wood screws to hold the tray to the spacer. I just used a counter sink and drilled them out first. I hope it holds. It seems to be ok.
As far as my RCPD order, we'll see when it shows up I guess. I'm trying to not make such a big deal out of it. I don't want to embarrass him or cause him bad publicity or anything. I just want to get this thing moving. I know some people would be trashing him out by now. He told me if I was tired of waiting he would refund my money but I told him that it was ok. I would wait.
I just sent GlassDoctor a check for an esc. So all I need now is a battery and a new charger. I have a superbrain 977 but I want to get the Hyperion with balance taps built in. It would probably be better in the long run.
I hope to be rolling in the next few weeks.
