kulangflow
Never Fast Enough
kulangflow's Avatar
02.28.2008, 08:49 PM
Originally Posted by BlackedOutREVO View Post
What motor are you using? You get a new MM already?
I mounted my spektrum RX on the servo, and I didnt have issues
For now I'm just using the 5700 you had in there with a new Sidewinder on 2s lipo. I'll probably try a 4600/MM combo from my Rustler on 3s, and I'll likely try the VXL system from my Stampede as well on 3s. I haven't sent your old MM in yet.
I'll try mounting the rx on the servo.
I would say rebind the receiver making sure the throttle stick is at neutral. The fail safe should be kicking in and it should go back to neutral but it sounds as though yours is full stick. If it becomes a major issue pull the receiver from the car and test it with just servos and see if it does the same thing. If it does contact horizon because they replaced mine which did the same thing at close range (except it would go to fail safe positions).
I'll try re-binding too.
Thanks for the suggestions!
