lutach
lutach's Avatar
03.01.2008, 11:01 AM
When I first saw the 125B, I was a little freaked out as the positive and negative power wires came out ot the same place. When it burned and I opened the case to see what had gone wrong, you could see that the problem might have started there. I like ESC that places the power wires at the corners. Like the ones I'm having made and the one Artur made. If my controllers gets done soon, it will be the first of it's kind just for cars. That would be too funny considering that the big players all have HV, but they are for aircraft. I have no clue why we haven't seen a HV controller for cars yet. To me all this companies are too greedy and only thinking about what the returns might be. Off topic: A lot of people are pissed of at a few Asian companies for pricing the products right (In my opinion). You can buy hard cased 3200mAh 7.4v lipo for $34.99 (used to be $49 which still is cheap). They use the same concept I use and when my controllers gets done, I will also use the same concept.
shawn197
shawn197's Avatar
03.04.2008, 11:58 AM
Hi, I saw the video footage of your daughter. She is lovely, and you must be very proud of her.
I think you have a lot of things to say about Quark Monster Pro 125B. Can I ask you to be more specific about the strengths and weaknesses about that particular ESC? I personally agree with you on that ESC having the + and - power wires coming out of the same place. And I think Quark should have made the case differently, so that it gets cooled more easily. Please let share your thoughts with me. Thank you ^^
  Send a message via MSN to shawn197
lutach
lutach's Avatar
03.04.2008, 12:26 PM
Thank you. She is my life.
I'm trying to have a HV controller made. The engineer was going to do a 200A capable of 14S lipos, but he used sample boards that did not handle the AMPs. So I asked him to do a 60A, 80A and 100A. I like HV (12-14S) as it helps keep the temps down. I've talked other companies about this and they make it sound impossible to do. I'm not an angineer, but I know it's possible as I have a Schulze 40.160 (14S lipos), Actonic120 (12S lipos) controller that has car mode. The problem is that most companies want to make things smaller and smaller, but then they say hardware is not compatible. Kontronik did a fantastic job with the Jazz 55-10-32 as it has a car mode. It is small and freakish powerfull. I only hoped Kontronik would make the Power Jazz that way as well. There are very good MOSFETs out there and they need to focus more attention on them. I like the MOSFET found in my HW and I know Cyclone will have a controller with the same MOSFET. The SHV from Castle also uses them. Most people should realize that with HV you won't need 200A. You can still use 4S, 6S, 8S or 10S lipos if you want. You will be able to go out and buy a smaller capacity pack at a great price. The way some controllers are built though, you can still have a controller put out 200 or more AMPs for the bursts. Keep in mind, in order to get power from a 6S set up you will need more AMPs (22.2V x 200A=4440 assuming your batteries can put out that much AMPs), with 10S set up (37V x 120A=4440 now a good 5000mAh pack will do that), with a 12S set up (44.4V x 100A=4440 that's better) and with 14S set up (51.8V x 85.71A=4440). Now 4440W is a lot of watts. Most people are happy with 1400 to a little over 2000 watts and if you devide 2000W/44.4V you will need 45A to get it and 2000W/22.2 will bring that number up to 90A. Kontronik, Schulze and Actronic are the only companies with good HV (real HV not 22.2 volts) car ESC. I apologize for the long post, but I like HV .
Edit: Also, a lower Kv motor tends to make more torque then a higher Kv motor does and one advantage of a electric motor is, powr from torque.
Fried Quark Monster Pro 125B
phatmonk
RC carbon junkie
phatmonk's Avatar
Fried Quark Monster Pro 125B - 03.04.2008, 06:29 PM
So do you think that the positive and negative shorted this out?It does seem to have started at the power wire end.This almost toasted my truck.I am very bummed to be out 275 bucks and no reply from quark.I have run the same Neu 1515/1.5D/F 14.8v in my MM holemod.I had to almost rip the top off my Losi 8t to yank the ESC out when it fried.The power terminals melted off the ESC.
lutach
lutach's Avatar
03.04.2008, 06:46 PM
That is a familiar site .
phatmonk
RC carbon junkie
phatmonk's Avatar
03.04.2008, 07:18 PM
So what are the chances Quark will replace my burnt crispy esc.
phatmonk
RC carbon junkie
phatmonk's Avatar
03.18.2008, 04:54 PM
Quark sent me a new 125b monster pro free of charge.thats great customer service thanks quark
