Andrew32
03.01.2008, 06:00 PM
yes, i removed the red wire from the MM and no, still waiting for my 4s so im running 12cell.
also, if looking at reciever, the CC maual says to install as fowwlowed
Servo white - Rd - Black
MM ESC Orange - - Brown
UBEC Brown - Red - Orange
wouldnt it be:
UBEC Orange - Red - Brown
03.01.2008, 06:19 PM
Your second list is correct.
All of the orange/white wires are signal, brown/black wires are ground, and red wires go in the center for 12v power.
If you servo is working correctly then you have it plugged in correctly, as the signal wires are closest to the center of the receiver case, and the black/brown wires are closest to the outside of the case.
Hope that makes sense.
Not sure what happened to the ubec, what brand is it?
Andrew32
03.01.2008, 07:35 PM
it is the Castle UBEC. I was so upset when it started smoking!
it was like the devil did it!
azjc
03.01.2008, 10:54 PM
sounds like it may be possible when you wired in the UBEC tou reversed the polarity
Andrew32
03.01.2008, 11:27 PM
i wish, that way i know waht happened.
but yea i def wired red to (+) and black to (-).
Andrew32
03.02.2008, 08:56 PM
just looking at the UBEC and i realized the UBEC side has a signal wire, why would it ned a signal?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
03.02.2008, 09:32 PM
It's used when programming via the PC. It's not needed I wouldn't think when being used normally.
