smokyracing
03.02.2008, 12:53 PM
ok I got some Arctic Alumina but the guy at the store told me if i use this I would never be able to get the heat sink off is this right ??? thanks for the help
GriffinRU
03.02.2008, 01:16 PM
Hopefully you do not need to take heatsink off again, after the mod.
And, it is true for rated temperatures, but once you overheated it a little bit it would come loose.
And make sure to apply thin layer.
Sammus
Sammus's Avatar
03.02.2008, 05:06 PM
Nah I heard that too, I just hit it with a heatgun the same. Sure its a helluva lot stronger than the standard stuff on the MM, but once you heat it up use a knife blade or something thin and sharp to get underneath and it just pops off. The original MM just fell off once I warmed it up.
