EVERYTHING going wrong....
Andrew32
EVERYTHING going wrong.... - 03.01.2008, 05:31 PM
just got everything to do a MM, 7xl, and UBEC for my E.
Wired everything up (except the receiver). and powered it up, everytihng seemed to go well then poof the UBEC is up in smoke with the heat shrink melting. So i disconnect and now my ESC flashes all led's constantly. Did i fry both?! what the heck happened?!
bdebde
That's All Folks!
bdebde's Avatar
03.01.2008, 05:45 PM
Are you running 4s lipo? Did you remove the red wire on the receiver plug on the MM?
Andrew32
03.01.2008, 06:00 PM
yes, i removed the red wire from the MM and no, still waiting for my 4s so im running 12cell.
also, if looking at reciever, the CC maual says to install as fowwlowed
Servo white - Rd - Black
MM ESC Orange - - Brown
UBEC Brown - Red - Orange
wouldnt it be:
UBEC Orange - Red - Brown
bdebde
That's All Folks!
bdebde's Avatar
03.01.2008, 06:18 PM
Black/brown should be (-) and should all be in a line, as well as white/orange in line and reds in line, except for esc red should be out.
03.01.2008, 06:19 PM
Your second list is correct.
All of the orange/white wires are signal, brown/black wires are ground, and red wires go in the center for 12v power.
If you servo is working correctly then you have it plugged in correctly, as the signal wires are closest to the center of the receiver case, and the black/brown wires are closest to the outside of the case.
Hope that makes sense.
Not sure what happened to the ubec, what brand is it?
Andrew32
03.01.2008, 07:35 PM
it is the Castle UBEC. I was so upset when it started smoking!
it was like the devil did it!
azjc
03.01.2008, 10:54 PM
sounds like it may be possible when you wired in the UBEC tou reversed the polarity
Andrew32
03.01.2008, 11:27 PM
i wish, that way i know waht happened.
but yea i def wired red to (+) and black to (-).
Andrew32
03.02.2008, 08:56 PM
just looking at the UBEC and i realized the UBEC side has a signal wire, why would it ned a signal?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
03.02.2008, 09:32 PM
It's used when programming via the PC. It's not needed I wouldn't think when being used normally.
Andrew32
03.03.2008, 12:40 PM
ok guys thanks for all yalls input. Called CC toay adn they are taking care of me!
Andrew32
03.04.2008, 03:39 PM
another question, i was looking at this photo
http://www.castlecreations.com/image...pack-thumb.jpg
im wiring two 2s2p packs together, am i supposed to follow this "multipack" wiring or wire the total of both cells
03.04.2008, 05:27 PM
4S you can go across both - this setup is for 6s+
If you go across one pack then yes you must follow this else you will rasie the ground to 7.4v = BAD
