03.02.2008, 11:29 PM
Do you think boiling the servo savers would help? I have not had a problem (yet) but maybe I do not jump mine as much as other people do.
rchippie
rchippie's Avatar
03.21.2008, 09:22 PM
Im thinking about getting a different motor for my crt.5. After using brian's calculator im looking at A 8s. This motor on 2s would spin about 31.000 rpm while my (current motor) 7s on 2s spins about 36.000 . would going to a 8s lesson the load on my MM & lipo by alot or not that much ? . i would have to gear up one tooth to get the same speed. Im also using 2.2 truck tires. Thank's
REAL MEN RUN BRUSHLESS
GO-RIDE.com
03.21.2008, 11:59 PM
Does your MM currently get hot? With a lot of guys running 4S in 1/8 buggies and truggies through a modded MM I would think 2S and and S can motor in the little crt.5 would be no challenge for the MM? If only your MM is getting overly hot have you considered a small fan? I know a lot of guys don't like them, but mines lasted for months in my crt.5 and i've broke about every plastic part there is on the truck.
I'm kind of in the same boat, but I'm looking for a motor with more torque than my Novak GTB/6.5 combo. My combo has a kv of 6400, but runs cool at the track geared 12:46 and truck tires, or 13:46 and buggy tires. I'd like to get MM & 7S or 8S, but I don't want to give up top speed if the Feigao can't turn a much bigger pinion. I think ultimately I'll wait a bit till I can justify a MM & Neu 1506 (5500kv).
E-8ight - Tekin RX8 2000kv/4S
rchippie
rchippie's Avatar
03.22.2008, 07:45 PM
My esc temp is fine. Im just trying to lower my lipo temp & gain a little more lowend if possible.
