Peter Zicha
Peter Zicha's Avatar
03.04.2008, 02:28 AM
Lincpimp I hope I didn't offend you..... the point I was trying to make was that if you can shoe horn the motors in they are great for the heavier models
03.04.2008, 11:29 AM
Not at all Peter, you have more experience with the KB than I do! I have 3 of them, 10l, 8xl, and 10xl. I have not had a chance to run them in anything yet, but I have purchased a few 6mm bore pinions and removed the front endbell and tapped it for a conventional bolt pattern.
I need to get the Aftershock conversion started, as I intend to run the 10xl on 8s-10s thru a HV85 esc. The motor should be ideal for the heavy truck, just hope my lipos can keep up!
I originally thought that BOOGIE was using the rcm chassis, and there is very little space for batteries with a motor bigger than 36mm in diameter. Since he has the kershaw mount and access to machine equipment, I see no reason for him not to run the KB.
